Brief Description: Updrill, deburr and rivet lower fuselage parts.
Updrill, deburr and rivet lower fuselage parts. Time consuming to make certain everything fit right. I removed the lower fuselage parts to rivet the assemblies. Other builders had done the same and to be honest I could not figure any other way to access areas that needed to be drilled and riveted.
The last thing a completed today was to remove the forward fuselage bottom skin and drill the cap seatbelt assembly. I still have some updrilling and riveting to do on C07.
Lower fwd fuselage parts completed and riveted.
Much easier to drill and rivet with bottom skin removed.
