Daves Sonex Web Site
Sonex Aerovee Tri-gear
W02
Installed aileron pushrod assembly to bellcrank.
Press fit the bushings into the pushrod end and installed per plans onto the bellcrank. Also installed the short aileron pushrod to the bellcrank.
Press fit bushing into rod end bearing.
Long pushrod attached to bellcrank.
Short pushrod between bellcrank and aileron
Sonex Aerovee Tri-gear Home
1483
Aft Fuselage
Aileron
Cowling
Cowling, wing tips,
Flaps
Fwd Fuselage
89
252
Horiz Stab and Eleva
Lights
Misc Hardware
Panel, Avionics, Wir
Polish
Turtledeck
Vert Stab and Rudder
Windscreen and Canop
Windscreen, Canopy,
283
