Brief Description: Fit Leading Edge Skin and clecoed to Main Spar.
I spent 30 minutes fitting the Leading Edge Skin and cleco to Main Spar. Eddie Van Horn helped to hold LE sheet in place for me to cleco into place. All holes lins up great and all of the ribs lined up perfect. However the root rib starts out about 1/16 inch off at the main spar and angles off line by 3/8 inch. It looks like the forward root rib attach bracket angle is off and may need to be closed up a bit.
I also fabricated a mounting plate for the Pitot/Static tube which I purchased from Aircraft Spruce.
