Daves Sonex Web Site
Date:  12-28-2010
Manual Reference:  W03
Brief Description:  Pilot and updrill right Aileron.
Tonight I pilot drilled the Aileron for the Hinge placement using the pilot holes previously drilled in hinge. I then measured and marked all pilot hole locations for the Center rib, Drive rib, and Counterbalance ribs. After test fitting and re-measuring about ten times I drilled all pilot holes and clecoed all parts together.
Drilling Aileron Skin
Cleco Hinge to Skin
Cleco Hinge to Skin
Pilot drilled and Clecoed Skin.
