Daves Sonex Web Site
Sonex Aerovee Tri-gear
W11
Attach Assemblies to the Right Main Wing Spar.
Tonight I worked on the Right Main Wing Spar and installed the following assemblies and parts.
W11-06 Root Wing Attach Assembly.
W20-2 and 3 Root Rib Attach Assembly.
W11-11 Outboard Vertical Stiffener.
W11-10 Tie Down Fitting and Assembly.
W11-02 End Wing Attach Assembly.
W20-02 Root Rib Attach Angle.
W11-R Tie Down Fitting
Sonex Aerovee Tri-gear Home
1483
Aft Fuselage
Aileron
Cowling
Cowling, wing tips,
Flaps
Fwd Fuselage
89
252
Horiz Stab and Eleva
Lights
Misc Hardware
Panel, Avionics, Wir
Polish
Turtledeck
Vert Stab and Rudder
Windscreen and Canop
Windscreen, Canopy,
283
