Well finally after nearly 2 1/2 years I've got something to show for the work.....a wing, well almost! Fitting the root rib was a right bastard, I think that the root should be rivetted once the angle bracket is bolted back to the spar, I elected to take it off to rivet which makes it really easy, but then getting the bolts in bolted up.........The skins are fitting quite well, the bottom has required tweaking a couple of ribs with the fluting pliers to get everything lined up but I haven't noticed any more grey hairs than usual.
Ribs and spars finally assembled.
Top skin clecoed in place, about to flip wing panel over to do bottom.
