I was making up these components while doing the tail plane. Due to missing out on ordering enough 3/16" x 2 1/2" angle to complete the rear tail plane spar I got started on the fuselage. This was when I discovered that I needed some nylon rod and 3/4" phenolic sheet to make the rudder cable thrust guides. Trying to order the right amount of material in the right order still does my head in! Now this sounds crazy, but after spending the last 3 years building a Sonex, I finally got to have a fly of one yesterday. It certainly helps with the motivation to keep going!
