Sonex 1093 Construction Log
Sonex
W21
Wings: LH Aileron Bellcrank Install / Aft Rib #9
Worked on the W21-01L left hand Aileron Bellcrank Assembly/Aft Rib #9.
* Made two new clips and forward channel piece.
* Attached clips to channels
* Measured, drilled and deburred rivet holes in rib
Clips, Channels, Rib
Attaching upper/lower angles
Rivet lines drilled
Sonex Home
774
Administration
Aircraft Kit
Controls/Rigging
267
Hardware & Supplies
Shop Setup
Tips & Techniques
327
