Sonex 1093 Construction Log
Date:  2-17-2009
Number of Hours:  1.30
Manual Reference:  W03-01L
Brief Description:  Ailerons: LH Aileron work
Have an EAA 44 Chapter meeting tonight - a builder's show and tell - and am taking the RH Aileron along. Only have a little time to work on the LH Aileron.
* Pulled off the protective covering and marked the cut lines for the outboard tip.
* Marked the cut lines for the Counterbalance opening. Cut out and smoothed the opening.
Marking cut lines for outboard tip. I like this ruler.
Used Andy Snip to cut up the sides
Bent and broke off the piece. Finished up by filing.
