Sonex 1093 Construction Log
Sonex
W03
Ailerons: RH Aileron work
* Scrubbed labels off ribs
* Drilled middle and inner ribs on RH Aileron, and trimmed out the Drive Horn and Counterbalance openings in the skin.
* Started work on assembling the RH Counterbalance Assembly.
Drive Horn notch
Drive Horn Assembly in place
Drilled across top, used snips on sides, filed smooth.
Sonex Home
774
Administration
Aircraft Kit
Controls/Rigging
267
Hardware & Supplies
Shop Setup
Tips & Techniques
327
