Brief Description: Wing LH Main Spar - drill bolt holes
* Made a "drill guide" from an aluminum block to keep hand drill vertical for bolt holes. * Drilled "tight fit" bolt holes for W11-06L Wing Tie Down Assembly using #13 drill bit. * Drilled the 8 bolt holes on bottom spar cap.
