Brief Description: Wing LH Main Spar - remove scratches
* Riveted W10-06L LH Tip Web Assembly.
* Removed scratches in top and bottom spar caps caused by sharp points on cleco pliers before I ground them off. Used Scotch Brite blue discs in hand drill, plus SB pads.
