Brief Description: Wing RH Main Spar - attaching spar caps
* Resumed fitting top and bottom RH spar caps to main web using Sonex spacers. * Lise helped hold things together until I had a few clecos in. * Drilled bottom spar cap to #40 holes; then to #21's outboard of the doubler section.
