Brief Description: Horiz Tail: Position elevator hinges on HS
* Clecoed piano hinge halves on rear edge of HS and matched up elevator hinges. * Then marked where root rib assembly should go to tie the elevators together.
Locating side to side position of elevators before riveting root rib assembly
