- Rudder: Removed drill marks inside rudder skin and set aside for riveting after priming. - Vertical Stabilizer: Drilled and deburred hinge pieces. - Horizontal Stabilizer Forward Spar Fitting T06-03: Used power drill and twist lock sander to remove tool marks. Worked on smoothing edges and surfaces.
