Finished dressing and drilling T06-03 Forward Spar Fitting. Removed orange peel at bends with sandpaper and Scotch Brite pad. Used Twist Lock pads (like Scotch Brite) on the power drill to remove the tooling scratches the edges.
TIP: USE A P100 RESPIRATOR FILTER. This creates a lot of aluminum powder that I don't want to breath.
Started T06-01 Elevator Horn Assembly by drilling and clecoing the LH root rib to it.
TIP: Needed an angle drill or flexible aircraft drill bits to drill the holes in the narrow places.
