Brief Description: Elevator Root Assembly - Replace Rib
* Drilled out old rivets to remove RH rib, which was misaligned slightly. * Primed steel control horn assembly. * Drilled, deburred and riveted the new rib on. Assembly is completed.
Found that the flattest surface in the house is a marble top lamp table, which I used this time to be sure the ribs are in perfect "planar" alignment.
