Sonex 1093 Construction Log
Date:  12-8-2008
Number of Hours:  1.50
Manual Reference:  T06-02
Brief Description:  Elevator Root Assembly - Replace Rib
* Drilled out old rivets to remove RH rib, which was misaligned slightly.
* Primed steel control horn assembly.
* Drilled, deburred and riveted the new rib on. Assembly is completed.
Found that the flattest surface in the house is a marble top lamp table, which I used this time to be sure the ribs are in perfect "planar" alignment.
