Sonex 1093 Construction Log
Date:  7-27-2011
Number of Hours:  1.50
Manual Reference:  W08
Brief Description:  Wing LH Main Spar - drill bolt holes
* Made a "drill guide" from an aluminum block to keep hand drill vertical for bolt holes.
* Drilled "tight fit" bolt holes for W11-06L Wing Tie Down Assembly using #13 drill bit.
* Drilled the 8 bolt holes on bottom spar cap.
