Sonex 1093 Construction Log
Date:  7-29-2011
Number of Hours:  4.50
Manual Reference:  W08
Brief Description:  Wing LH Main Spar - remove scratches
* Riveted W10-06L LH Tip Web Assembly.
* Removed scratches in top and bottom spar caps caused by sharp points on cleco pliers before I ground them off. Used Scotch Brite blue discs in hand drill, plus SB pads.
Won't make this mistake on the RH spar!
