Sonex 1093 Construction Log
Date:  7-31-2011
Number of Hours:  3.75
Manual Reference:  W08
Brief Description:  Wing RH Main Spar - attaching spar caps
* Resumed fitting top and bottom RH spar caps to main web using Sonex spacers.
* Lise helped hold things together until I had a few clecos in.
* Drilled bottom spar cap to #40 holes; then to #21's outboard of the doubler section.
