Sonex 1093 Construction Log
Date:  8-1-2011
Number of Hours:  5.00
Manual Reference:  W08
Brief Description:  Wing RH Main Spar - drilling
* Finished drilling top and bottom spar caps to #40 holes using pilot holes in MS web as guide.
* Drilled rivet holes with #21 bit on outboard end up to the doublers. Skipped rib locations.
* Cleco'd the 3 web doublers to the main web.
* Marked up Main Spar Web W10-01 with locations of all rivets, bolts, screws and attachments.
* Drilled the doubler "sandwich" through all holes with #40 bit.
* Drilled up to #30 except where attachments go. Waiting for long reach clecos to arrive.
Stopped for the night.
