Sonex 1093 Construction Log
Date:  5-7-2010
Number of Hours:  4.00
Brief Description:  Wing Spars - dressing spar caps and spar webs
Begin dressing edges and corners of all webs and spar caps. Per Sonex instructions, need to remove machining marks from spar caps and the small ridge remaining where they removed part of the original angle stock. I doing this with the Vixen file and Scotch Brite pads.
Finished both main spar webs and the W10-02R & W10-02L aft spar webs.
