Brief Description: Installed tip ribs, and added L-brackets to the el
I positioned the tip rib bracekts in place on the main spar, and drilled/clecoed the tip ribs in place on the main spar. I then added L-brackets to the elevator rear support to be mounted in between the two inner most rear ribs.
