Using snips and multiple files, I cutout a curve on the rear mounting bracket used to mount the horizontal stabilizer onto the fuselage. I then laid out all rivet marks, and drilled the pilot holes on the bracket. Finally, I positioned the bracket in place, and mounted it to the rear spar with clecos.
Cutout curve on rear mounting bracket on horizontal stabilizer
Laid out and drilled pilot holes on rear mounting bracket
