Brief Description: Drilled and clecoed rear ribs and front rib to spa
With the doublers in place, in accordance with my plans, I drilled and clecoed the rear ribs onto the spar, and then drilled and clecoed the front rib on the spar aswell.
I laid out and aligned the ribs onto the spar, and drilled and clecoed the rear ribs in place
With the rear ribs in place, I drilled and clecoed the front rib in place
