Dennis's Web Site
Date:  12-17-2014
Number of Hours:  4.00
Brief Description:  Fuel reservoir spouts.
My wing-tanks came pre-fitted with inlet/outlets from icp, instead of using the standard 6mm mounted return inlet used by the 912 ill use it as a gas return line from the reservoir, mount a new 10mm and 6mm outside diameter fitting on the reservoir.
