Assembly of Stabilizer went in a comfortably good speed, trying to follow the instructions isnt so easy as i thought. Is not that i dont understand english, its the lack of a good translation in the manual that explains it in a weird way, its inconclusive.
But assemble and later on you see what you didnt do and then correct it, i have a feeling this will happen more often.
Every part accounted for except sc300, a plastic part from the NOSE UP cable that i had putted in box nr 18 in Tierp.
Finally its was assembled and now its time for dissassembly to paint it with anticorrosion paint.
