My RV-8 Project
Date:  2-28-2014
Number of Hours:  8.00
Brief Description:  Setting toe
While I had the fuselage center line marked for the weight and balance, I decided it was time to check the toe. Sure, it's checked while the fuselage is under construction but with an RV8 it's a good idea to check it with weight on. I ended up putting a 1/4 degree shim on both axles, one correcting a tiny bit of toe in, the other a tiny bit of toe out.
