Brief Description: Drilled Canopy frame for rollers
What to do while the sikaflex cures? This morning I drilled the frame for the rollers and the Mike Zeller canopy stop. Mike really should do a better machining job. If we wanted to make it ourselves, we would do so. If you're going to sell a kit...I think the parts should at least fit each other. In any event, not hard to fix but he acknowledges in the napkin he includes as a plan that the builder is doing 51% of the fab....I find that odd. The pendulum wouldn't even slide onto his machined bushing, let alone free wheel like it needs to in order to operate. Also, it would kill him to include the 24 cent bolt that matches Van's other side and a nut and washer? I had an AN3 bolt that works for now...but will order the matching AN525-10R24 from Spruce.
