And so the saga continues. I took an inch off of the skirt bottom all the way around, then added it back..but this time it lays flat on the fuselage. The first two pictures are after three layers of cloth topped with peel ply. The red tape line you see through the glass is where Vans skirt ended. The black line you see in the last shot is my first cut line. It's about 1/4 longer than vans skirt. Thought is to fill etc then cut to final shap which should give me a cleaner edge.
