My RV-8 Project
Date:  4-8-2013
Number of Hours:  5.00
Brief Description:  Canopy Skirt day 3
This morning I pulled the skirt off (popped right off the release agent!) and put a few lay ups on the under side above the track and the slice we had to put in the right side to get it to lay down. I also flattened the top edge with a sanding block.
Then I mounted the skirts back on the fuselage and did some shaping with a DA sander followed by a sanding block. I then performed Dan Horton's birthday cake trick by mixing up a batch of micro balloons and epoxy and spreading it on like cake icing. After that dries I'll sand it down and see where I stand. So far, this is going splendidly! It's not done yet though.
