I'm getting pretty good at this infinity grip business. Because I opened the bottom of my panel a bit, I now have more clearance to play with. That means the stick I already performed surgery on was shorter than it needbe. So, I performed surgery on stick number two.
This time I opted to combine the ground wires inside the stick, making the hole needed in it smaller. I then put some shrink wrap over the wires as they came from the grommet. I put the hole on the side this time as well.
