Brief Description: Finished up GTX23es remote transponder
Finished up the wiring harness and installed the Garmin GTX23es remote transponder. I considered installing the antenna as well, but settled for just running the coax since having an antenna on the bottom without gear on would just mean I had to remove it later. Also ran the RG400 for the comms, but didn't drill any holes for the same reason. Antennas will be a job done at the airport once she stands on her own three legs.
