Brief Description: Instrument test fit and dynon flush mount mod
So, decided I should see how things fit and get the things rivetted to the panel that need be before I send it off for paint. The dynon D6 flush mount bracket needed modification to make work but that wasn't a problem. I still need to rivet on the angle for the radio stack, but struggling a bit with that since I don't have the actual units, only the trays....and the PAR100EX doesn't have a drawing showing how far off the panel the face sits...so I'm not sure where to align the trays and therefore how deep my angle needs to be.
Two other small notes. The screw holes for the autopilot were drilled too small from Stein and the ELT cutout is too small. I drilled out the AP holes in a jiffy and will need to cut the ELT hole larger once I pull the panel back out. Neither is a significant complaint.
