Brief Description: Glare shield vinyl and defroster
The thing about fiberglass is...once you lay it up you can't mess with it until the next day..at least that's the case in the basement of a Denver house with it snowing outside. Even fast hardener...isn't fast.
So, while searching for anything that I can do that doesn't require me to move the canopy...I set the windscreen in place, marked it's location and cut the vinyl that will sit up there. Then I marked the defroster hole and cut it out of the vinyl and test fit the grill. Took it all off and stored it for later.
