Brief Description: Pitot/Static lines through the panel
I struggled a bit with how to run these lines. Due to my ridiculous amount of electronics and putting some of it under the floor boards, my wing spar penetrations are pretty much full. So, I've had to resort to other routing to get stuff from the back to the front of that wing spar. I chose to run the static up the left side and under the side rails while the pitot makes a circuitous route back from the left wing around the battery and back up the side rail. It's a bit odd, but I am going with it. I will likely paint those tubes to match the interior....
****A few day later...and I am reconsidering the pitot tube running all the way to the rear and back forward.....
****Yeah, didn't like it. Later kits had an additional hole through the spar, which Van's said I could add...so these are run under the floor now.
