I installed two relay terminals and a ground block between the ribs under the cockpit floor. I connected the cockpit ground block to the firewall ground block with an 8 AWG wire. The two relay terminals give me 13 connection points to connect the stick switch functions, connect nav/strobe/beacons, etc.
Installing relays under the cockpit floor
Adel clamps to into the top edges of the tunnel floor
