Brief Description: First look at the wiring harness
When Stark Avionics built my panel and programmed my Vertical Power Pro VP-X system, they provided a full wiring harness for all my systems...basically as close to a "plug-and-play" setup as you can come. However, it still results in a wiring harness that looks at first like a sort of "rat's nest." The key is to run each wire one at a time as smartly and safely as I can. I'll intall adel clamps as I ID places where it's logical and smart to secure the wires. It's time consuming, and you'll see several sets of photos over the next few weeks as I run them.
