Brief Description: Main Instrument Panel, air vents
I finally mounted the main instrument panel into place, and also mounted the two air vents. Once everything was lined up, fitted, and drilled, I disassembled the entire panel assembly. I then: - Deburred, dimpled, and countersunk. - CAREFULLY deburred the firewall flange rivet holes. - Primed the rest of the surfaces (except for the main panel thinking I'll still be handling it a lot, but that may be the perfect reason to go ahead and prime).
