Brief Description: Autopilot roll servo, right wing #1
Installed Dynon's autopilot roll channel servo. This will link via data cable to the Dynon SkyView EFIS I plan to install.
Dynon actually enclosed a link tube many inches longer than the 3-inch requirement. We measured and cut the tube down to 3 inches, then tapped the unthreaded end. Houston did a great job tapping the end of the link tube that connects the servo arm with the aileron bell crank.
