Sid & Houston Mayeux Project
Date:  2-25-2014
Number of Hours:  3.00
Manual Reference:  SB 14-01-31
Brief Description:  SB 14-01-31 part 4, positioning the spar doublers
I seperated the two halves of the doublers that came with the SB kit. I measured, drilled, and deburred the rivet holes on the doublers: Note that they don't align with any existing rivet holes on the stab spar. I clamped the doublers to the spar, taking care to marry the doubler's bend with the spar bend, thus placing the spar/doubler faces flush. Clamped in place, I matchdrilled through the doubler holes into the spar, then vice versa, cleco-ing each hole.
Positioning the doublers
Note measured/drilled rivet hole positions
Forward spar with angle bars, match-drilled to doublers
