Sid & Houston Mayeux Project
Date:  8-20-2013
Number of Hours:  3.00
Manual Reference:  Stabilizers on
Brief Description:  Installing the horizontal/vertical stabilizers
Big day! I final-installed the horizontal and vertical stabilizers! I superglued a washer onto the aft/left side of the elevator horn stop: This gives the vertical stab a slight turn to the right, which helps offset prop P-factor and gyroscopic precession during the takeoff power-up. With the stabilizers mounted, I installed all hardward and tightened them all to 25 inch/pounds torque (AN3 bolt/nut value).
Offset washer glued into place
Tail on!
Tail on!
Mounting bolts/screws torqued
