Sid & Houston Mayeux Project
Date:  2-19-2011
Number of Hours:  3.00
Manual Reference:  Elevator
Brief Description:  Elevator trim tab
The trim tab is next. First we riveted the trim tab spar's bottom side to the skin. You can see the rib I fabricated into the skin to the side of the trim tab cutout.
Next, lots of small adjustments as we test-fit the tab, clamped to both ends of the piano hinge, to get it lined up with the inboard edge and (most importantly) the elevator's trailing edge.
Riveted the bottom spar
Lining up the piano hinge
