Sid & Houston Mayeux Project
Date:  2-19-2011
Number of Hours:  3.00
Manual Reference:  Elevator
Brief Description:  Riveting left elevator skin to skeleton
Next we riveted the skin onto the left elevator skeleton. Easy going except for that last rivet.
In image 2, you see me using my thin-but-solid tire iron as a back-rivet bucking bar. I clamped the elevator down flush to my steel plate, and used the tire iron as an offset surface to which I can apply force from my rivet gun to the rivet shop head.
Slow and steady, under higher pressure. Worked great!
Riveting the counterweight skin to its ribs
Improvise!  Setting that last rivet back in the rib
Skins are on!
Skins are on!
