Sid & Houston Mayeux Project
Date:  1-9-2011
Manual Reference:  Rudder
Brief Description:  Assembling the lower rudder skeleton
Proper assembly of the rudder skeleton's lower pieces takes close study of the directions. It requires some fab work to make a shim, and trimming the rudder horn's upper corners to fit into the rib.
Cleco bottom rudder rib
Matching up the rudder horn with rib
Match drilling
Match drilling
