Brief Description: Finishing up Horizontal Skeleton
Took a hiatus. Had some work issues and then I needed some new tools and a couple parts from Vans because of errors I made building the front HS Spar. I basically reordered the front spar and started over. When I built it the first time it turned out great. The problem was when I tried riveting on HS-00005 and HS-00006 I really messed up the riveting...When I tried drilling it out this is when things went south quick!! Ugh!! Made a figure 8 hole and really buggered it up. I just walked away at that point, regrouped and reordered all the parts I needed.
I can report once I received the parts, I used the old parts to practice, practice and practice some more. I finished it and it looks good!! Whew!
