Brief Description: Disassembled right HS skeleton from skin
Disassembled right HS to get ready for sanding, filing and deburring before priming. Found I will be using a oops rivet on right side nose rib HS-707 bottom. I elongated that hole for some reason. Fortunately I bought the oops rivet set from Avery so I have some recourse. Just going to enlarge that particular hole to #30 on both the rib and skin and you will never know. Probably would be ok if I just went for the AN426 3-3.5 but I want this to be solid.
