Brief Description: Clecoing on the Left HS-601PP Skin to Skeleton
Used my soldering iron and removed the rivet line blue protective coating off the outside of the skin. Totally removed the inner blue coating on the inside and clecoed in the skeleton. The skin has alot of tension and required a bit of muscle to get it into position.
