BRIAN'S WEB SITE
RV-7
Section 6 Fr, Spar
Marked the HS-710 & HS-714 for taper cuts
Marked both HS-710 and HS-714 for cutting the taper. Used a flat die for the radius because it happened to be 1/2 diameter which means the radius is 1/4. Worked out very well!
Marks Made for Cutting
RV-7 Home
101
76
